TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin engine question's
JOB
05-29-2013 16:57:20
Sounds way over my head. It would be a lot easier on my head just to run what works.
I am thinking now that if the VG4 is even fire the VH4 distributor will work on it. The piece the distributor bolts into would have to have the same gear as the other engine and the idler gear would have to be the same also. That even confused me.If the idler gear turned the same distance per revolution I would say the housing or generator that the distributor fits into would work on either engine. If I am wrong let me know. I have been wrong before.
Duner Wi
05-29-2013 18:01:03
 Re: Wisconsin engine question's in reply to JOB, 05-29-2013 16:57:20
This might help, not certain if all VG4 were even fire. All I ever worked on Were VE4,VF4 VH4. If you have a distributor drive it should be 1/2 speed . I revolution of rotor for 2 revolutions of crankshaft. WI magneto’s were most or all full speed. One revolution of MAG for 1 revolution of crankshaft. http://www.smokstak.com/forum/showthread.php?t=76987
JOB
05-30-2013 04:15:21
 Re: Wisconsin engine question's in reply to Duner Wi, 05-29-2013 18:01:03
I read your smokstak thread and am still confused, except for the part where it says you can not interchange a half speed distributor with a full speed distributor. I would think if you changed what ever is in between the distributor and the idler gear at the same time the distributor would work????
I am trying to modernize a 1965 vintage VG4 to electric start. The parts I am planning on using are coming off an older VG4. The older VG4 has the 3 inch round holes in the sheet metal at the back of the engine so you can clean out schaf from around the cylinders. That is why I think it is older.
