Yesterday's Tractor Co.
Shop Now View Cart
Stationary Engines Discussion Forum
Re: Ford 172 stationary power unit
05-02-2013 17:25:30
Thanks for the help Bob, I Tried the opening the points with a screwdriver and having a grounded spark plug, and could not get a spark.
I borrowed a coil off a similar engine and put it on the 4 cylinder engine and had the same luck with the screwdriver. I then took the coil wire and held it a 1/4 inch or so from ground and spun the engine with the starter motor. Had plenty of spark. I am now up and running but one coil short.
I now understand how the ignition system works sort of. The points act as a switch, but how does the opening and closing of the switch make the coil fire? Thanks again Bob I need that chipper off and on all summer.
05-03-2013 00:48:33
 Re: Ford 172 stationary power unit in reply to JOB, 05-02-2013 17:25:30
The buildup of a magnetic field in the coil when the points are closed and it's collapse was points open, causing a spark from the secondary winding is explained in the first 3 pages of the previously linked manual FAR better than I could!.
05-03-2013 01:21:13
 Re: Ford 172 stationary power unit in reply to Bob, 05-03-2013 00:48:33
I looked at that link. If I would have done that when you first posted it I would not have had to ask so many questions and take up your time. When it mentioned John Deere I thought it pertained to John Deere. I should have known all ignition systems work basically the same way. Thanks Bob
