Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Ford 172 stationary power unit
Bob
05-02-2013 07:43:10
You wrote "On the distributor side of the
coil I get .079 volts. Isn"t that kind of low on
the distributor side of the coil?"
NO! Not with the points closed.
Connect a spark tester (spare spark plug) to the secondary terminal (tower) on the coil and using an insulated tool, open and close the points.
You should see a small spark at the points each time they open and a good, hot spark coming out of the coil each time.
If not, the coil MAY be bad and the condenser is a possibility.
Here is a link to the John Deere FOS manual for ignition systems, as posted on the Farmall Cub site. That MAY give you some further insight into this.
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/FOS-20%20Chapter%206-Ignition%20Circuits/index.html
JOB
05-02-2013 17:25:30
 Re: Ford 172 stationary power unit in reply to Bob, 05-02-2013 07:43:10
Thanks for the help Bob, I Tried the opening the points with a screwdriver and having a grounded spark plug, and could not get a spark.
I borrowed a coil off a similar engine and put it on the 4 cylinder engine and had the same luck with the screwdriver. I then took the coil wire and held it a 1/4 inch or so from ground and spun the engine with the starter motor. Had plenty of spark. I am now up and running but one coil short.
I now understand how the ignition system works sort of. The points act as a switch, but how does the opening and closing of the switch make the coil fire? Thanks again Bob I need that chipper off and on all summer.
Bob
05-03-2013 00:48:33
 Re: Ford 172 stationary power unit in reply to JOB, 05-02-2013 17:25:30
The buildup of a magnetic field in the coil when the points are closed and it's collapse was points open, causing a spark from the secondary winding is explained in the first 3 pages of the previously linked manual FAR better than I could!.
JOB
05-03-2013 01:21:13
 Re: Ford 172 stationary power unit in reply to Bob, 05-03-2013 00:48:33
I looked at that link. If I would have done that when you first posted it I would not have had to ask so many questions and take up your time. When it mentioned John Deere I thought it pertained to John Deere. I should have known all ignition systems work basically the same way. Thanks Bob
