AZ GARY
I'm having trouble installing the head and getting the carb flapper in the right position. I know it should be open to start. But the shaft from the crankcase turns cckl wise from the start position but the flapper can only turn clk wise. I've put the head on before and never had a problem. What have I done wrong?
I found my problem, I put the flapper in the carb on the wrong side of the shaft so it opened the wrong way. I've had the head off before, I guess I was lucky, because I didn't know you could get it wrong.
