Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin vg4d starting problems
ohiojoe
03-23-2013 10:55:15
Normally LP is supplied at 14 inches water column pressure (.5 psi) to the generator. You would need a regulator at the LP tank to drop tank pressure to 14". Hopefully the only problem you have is the Eaton valve would not open under full tank pressure (which can be as high as 250 psi). A 20lb tank can not supply enough volume to run the generator, but should be able to start it.
