Idenity of wisconsin engine trpe TH
wilson ind
How does 2 cylinder type TH fire. Each revolution or as on a John Deere 180 degrees then 540 till number one fires again.. I do know wisconsin makes both types for the 3& 1/4 Square engines. Thanks fellows Bill Wilson
The 2 cyl Wisconson engines can be ether even fire or odd fire like JD 2 cylinders were. Even fire one like my LP gas is has both pistons at TDC together, and mag fires both plugs at the same time. Crank, cam, and mag are diferrent between the two designs. Trying to remember, think TE, TF, and some TH were even while TJ and some TH were odd fire. I have some TH and a TJ to play with.
