Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin head bolts
Duner Wi
12-21-2012 06:54:53
My Jan 85 VF4 manual says to use mixture of graphite and motor oil.
JOB
12-22-2012 08:34:53
 Re: Wisconsin head bolts in reply to Duner Wi, 12-21-2012 06:54:53
Sounds like they were or are aware of a problem removing head bolts without twisting them off. I wonder if never seize is an equivalent of the motor oil and graphite. I would guess the motor oil was used to make the graphite stick to the bolts. If their factory would have used something, us in the field would not have had to worry about twisting off head bolts. Those center three are impossible to get at with a torch. I can remember a bolt or two not feeling good when I started to take it out. I used the torch to heat the block area of threads and removed the bolt with no problem.
I think I might try the never seize. I don't think I will be the one removing these heads in the future.
Duner Wi
12-22-2012 16:39:36
 Re: Wisconsin head bolts in reply to JOB, 12-22-2012 08:34:53
I might try this. Have done this for bleeder screws on wheel cylinders and it works most of the time. Use my air impact and set at lowest setting and work up . It is better to go slow than fast. Rattle on it for a minute or so . Might shake something loose.
