| Stationary Engines Discussion Forum |
Topic: Re: Wisconsin head bolts
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Kent Petersen
12-20-2012 01:03:11
209.62.251.218
if you look in from top side of the jugs you can see some of the head bolts stuck thru the treads and can rust on ends these are the ones that brake all the time when you remove a head i use a litter shorter cap screw in place off them stops that trouble and yes use anti sizes these bolts are in the middle of the head between cyls |
| JOB
12-20-2012 07:28:59
74.36.128.187
Re: Wisconsin head bolts in reply to Kent Petersen, 12-20-2012 01:03:11
| I would bet that one flat washer would be enough to keep the head bolt from sticking far enough out to rust. I know when you bolt things together you should have a minimum of a thread and a half maybe more beyond the nut. That might not apply here. |
| Duner Wi
12-21-2012 06:54:53
216.226.80.242
Re: Wisconsin head bolts in reply to JOB, 12-20-2012 07:28:59
| My Jan 85 VF4 manual says to use mixture of graphite and motor oil. |
| JOB
12-22-2012 08:34:53
74.36.128.187
Re: Wisconsin head bolts in reply to Duner Wi, 12-21-2012 06:54:53
| | Sounds like they were or are aware of a problem removing head bolts without twisting them off. I wonder if never seize is an equivalent of the motor oil and graphite. I would guess the motor oil was used to make the graphite stick to the bolts. If their factory would have used something, us in the field would not have had to worry about twisting off head bolts. Those center three are impossible to get at with a torch. I can remember a bolt or two not feeling good when I started to take it out. I used the torch to heat the block area of threads and removed the bolt with no problem. I think I might try the never seize. I don't think I will be the one removing these heads in the future. |
| Duner Wi
12-22-2012 16:39:36
216.226.80.242
Re: Wisconsin head bolts in reply to JOB, 12-22-2012 08:34:53
| I might try this. Have done this for bleeder screws on wheel cylinders and it works most of the time. Use my air impact and set at lowest setting and work up . It is better to go slow than fast. Rattle on it for a minute or so . Might shake something loose. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
