McC-Deering LB
Bob Harvey
Just an update. Haven't had much time to phart around with my 'toy'. I've done a few minor things (new plug & wire, cleaned gas tank, cleaned exterior of gunk)and bought some stuff from 'Hit-N-Miss' (tank lid, muffler, handle return spring and decals). Anyhoo, gave it a whirl today - started on 2nd pull! Kool.
Once you get the thing running properly don't touch the carb setting again. A man told me at a show one time his dad always said those engines were the only ones he ever saw that there could be nothing wrong with them and they would not start. I have had 3 and still have 2 and can agree with that statement. when you cut it off kill the ignition instead of cutting the fuel off. They are good dependable engines but once in awhile can be a PIA.
This thing does't have a kill switch/button. The manual says to turn off the fuel. Suggestions? It has always worked with shutting off the fuel and started with 1 turn open, then fine tune. Might have simply flooded it - we'll see. Thanks.
Should be a little nut type thing on back of mag, that is where you would hook a kill switch.
