Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Wis VH4D
Bernie/MA
08-18-2012 15:54:54
The manifold ear broke off and let the gasket blow out. I ran it that way for a couple years on my Hesston, finally decided to fix it with a manifold off a parts engine. I got the nuts off the studs by running it til hot and putting beeswax on (in case this helps somebody). Running with no gasket has left the seat rough. Should I put anything on the seat and/or gasket?
george md
08-23-2012 22:04:39
 Re: Wis VH4D in reply to Bernie/MA, 08-18-2012 15:54:54
Bernie,
I had one in to fix that the curve in the manifold had straightened out some and the port in the block burned away as well as the manifold. acetylene welded both and machined both . Had to build the manifold port sideways with the weld to get the ports to line up .
george
Bernie/MA
08-25-2012 18:08:02
 Re: Wis VH4D in reply to george md, 08-23-2012 22:04:39
I was gonna ask this general, but you probably know. Where the manifold seats the bolt area is lower than the gasket tops. How much is the manifold supposed to be tightened down? Do I use a torque wrench? What is the setting?
george md
08-25-2012 18:47:07
 Re: Wis VH4D in reply to Bernie/MA, 08-25-2012 18:08:02
Bernie,
I think there is a slight boss where the gasket seats . The genuine wisconsin book says 40 to 50 pounds torque .
george
Ian Beale
08-19-2012 01:06:34
Have a look at CRC Maniseal
Bernie/MA
08-25-2012 18:11:28
 Re: Wis VH4D in reply to Ian Beale, 08-19-2012 01:06:34
I couldn't find that around here. Useing a permatex product good for 700 degrees.
Copyright © 1997-2015 Yesterday's Tractor Co.
