TractorLinks.com
Stationary Engines Discussion Forum
Re: greygoat, Duner
JOB
06-24-2012 17:17:14
You guys were right on, it was a valve not going down all the way. I poured the cylinder full off oil with the intake valve open, tipped the engine so oil would go down into the intake port. Did the same to the exhaust valve and got some oil into that port. Let it sit for a day and a half. Still had no compression. Used Duner's compressed air idea, and had air coming out the exhaust manifold. With all the plugs out turned the engine over several times and I had compression.
Thanks Guys
That old VE's block was not drilled and taped for the starter motor support hanger. It does have indents where the holes should be. Looks like I will drill and tap some holes so I can put the starter on.
Duner Wi
06-24-2012 20:17:27
 Re: greygoat, Duner in reply to JOB, 06-24-2012 17:17:14
Thank you for the rest of the story.
JOB
06-25-2012 18:08:58
 Re: greygoat, Duner in reply to Duner Wi, 06-24-2012 20:17:27
No problem, you guys were nice enough to give me suggestions and ideas. Sometimes I just don't think of good ideas. The least I could do was tell you how I fixed it with yours and greygoats help. Thanks
