| Stationary Engines Discussion Forum |
Topic: Re: Removing Wisconsin flywheel
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Duner Wi
06-16-2012 13:01:58
216.226.80.242
From the Archives.http://www.ytmag.com/cgi-bin/viewit.cgi?bd=station&th=13375 I know the ring gear will inter change . |
| JOB
06-16-2012 15:46:06
173.84.196.130
Re: Removing Wisconsin flywheel in reply to Duner Wi, 06-16-2012 13:01:58
| Thanks Duner, I asked greygoat a couple of questions would you be willing to put your thoughts into this. |
| Duner Wi
06-16-2012 16:53:10
216.226.80.242
Re: Removing Wisconsin flywheel in reply to JOB, 06-16-2012 15:46:06
| For the cylinder with no compression take the valve inspection cover off and see if you don't have a valve stuck open. Flywheels have a bunch of parts #s. No starter. Starter with generator, starter with 10 amp alt. Starter with 30 amp alt. Closest # I see is N101 for VE VF 4 with 30 amp alt. VH4 shows #101A. Is the A important ? I don't know. If greygoat says it will work I would trust that. |
| JOB
06-16-2012 19:35:01
173.84.196.130
Re: Removing Wisconsin flywheel in reply to Duner Wi, 06-16-2012 16:53:10
| | On the flywheel fitting, I was just concerned if it would fit the taper properly. The old VE did not have an generating system in the flywheel, I would bet all they had was an external generator with a distributor on the end of it. I trusted greygoat on it fitting what I was wondering was how you folks remove a flywheel. I kind of explained how I did it. It was not the recommended method. Was wondering if the recommended method works for you guys. As for the #1 cylinder that has no compression I looked down the spark plug hole and can see both valves going up and down. I feel there is some stuck rings on the piston I have the engine tilted now with the top of the piston being level with a fair amount of penetrating oil in the cylinder. |
| Duner Wi
06-16-2012 20:05:03
216.226.80.242
Re: Removing Wisconsin flywheel in reply to JOB, 06-16-2012 19:35:01
| I tension the flywheel in the direction it comes off. After that it was pretty much the same way you did it. Put piston at TDC fire stroke and put compressed air to spark plug hole and see where air escapes. |
| JOB
06-17-2012 04:23:11
173.84.196.130
Re: Removing Wisconsin flywheel in reply to Duner Wi, 06-16-2012 20:05:03
| I will let the penetrating oil soak a little more, if nothing happens I will try the compressed air. Not sure how I will plumb it into the spark hole. Could just stuff rags around the hole. Thanks |
| Duner Wi
06-17-2012 06:13:52
216.226.80.242
Re: Removing Wisconsin flywheel in reply to JOB, 06-17-2012 04:23:11
| Auto parts store should have an adapter. Rags might work too being you have zero compression. I have made an adapter out of old spark plug. |
| JOB
06-18-2012 01:38:28
173.84.196.130
Re: Removing Wisconsin flywheel in reply to Duner Wi, 06-17-2012 06:13:52
| After you said auto parts store I remembered I have a screw in compression tester. The fittings on that should do the job. I still have it soaking in penetrating oil, poured in about a half of a small container. Was going to give it a couple of days. The first soaking of a little penetrating oil for one day did not work. Thanks |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
