TractorLinks.com
Stationary Engines Discussion Forum
Re: Stover 2 HP
kkaddatz
04-10-2012 18:08:00
I had a similar crack in an INT.LA 3-5hp engine. It was far enough back that the rings didn't travel over it. So I took the piston out and used a mini grider to open the crack up some more and then used some J.B. Weld to fill the crack and then honed it down some. Since the rings didn't travel over it the J.B. Weld sealed it up. That was over 15 years ago and it's still running.
huntingreen2day
04-10-2012 22:33:04
 Re: Stover 2 HP in reply to kkaddatz, 04-10-2012 18:08:00
Thanks for your reply. The rings don't travel over this area of the cylinder either. Is all JB Weld the same?
kkaddatz
04-12-2012 17:19:19
 Re: Stover 2 HP in reply to huntingreen2day, 04-10-2012 22:33:04
I just used the original stuff. Go to their web site and look, they have different stuff for different application, but it looks like the original is the one to use. Make sure you have it good and CLEAN for it to hold. Once I had the crack opened up I used starting fluid to clean it out. Starting fluid will cut any oil in the metal. Also make sure you clean out the sump. You don't want any metal grindings getting into the bearings. Good Luck.
