Yesterday's Tractor Co.
Shop Now View Cart
Stationary Engines Discussion Forum
No spark from Mag
04-07-2012 14:27:47
Hi guys someone gave me a small wisconsin air cool engine with external mag. fairbanks morse FM
I cleaned all the contact and points, Is there a way to test to see if coil is no good? I would like to trouble shoot it before I spend money on it or send it down the road. oldiron29
Bob Harvey
04-13-2012 16:49:02
 Re: No spark from Mag in reply to oldiron29, 04-07-2012 14:27:47
'Marks' in Penn. 860 537 0376 helped answer my questions. HTH
04-12-2012 06:47:03
I've got a Magneto coil tester that could give
you an answer in seconds..I'm in Western Wis.,
near LaCrosse An "Old Magneto Man" however did
the test under a heat lamp, for 15 minutes or so,
as they're more likely to fail as they get hot.
Finally..if the points look ok and are gapped
properly, the thing that most often fails, even
when sitting, is the condenser.
Magneto points, condenser,coils, are still
available, Y/T even has them,under electric parts
my e-mail is open if you need more help.
04-13-2012 03:43:08
 Re: No spark from Mag in reply to greygoat, 04-12-2012 06:47:03
Greygoat, I will see if I have a condensor on the shelf from an F-4 I think it is the same.
04-20-2012 20:15:54
 Re: No spark from Mag in reply to oldiron29, 04-13-2012 03:43:08
Take the condenser our and clean it with fine sand paper. Also clean any brackets that hold the condenser or places in the magneto where it sits. This has worked many times for me.
