TractorLinks.com
Stationary Engines Discussion Forum
Re: ONAN Gen Problem
Billy Shafer
01-21-2012 13:42:22
Should be a BFA. Look under the band over the brushes. You will find a resistor. If it is open it will run until you let go of the switch. Low oil pressure switch will also do it. But more common was a bad resistor. Look on top of the block for six numbers stamped into the block. That is the serial number. With it I can find out what you have.Also don't run it with the cover off of the head it will over heat. Short runs for testing are ok.
