TractorLinks.com
Stationary Engines Discussion Forum
Valve spring compressor
JOB
11-24-2011 18:55:33
You folks that work on Wisconsin engines, what do you use for a valve spring compressor. The compressor that is shown in the VF4 book is too large to get around the valve spring seat. The seat is real close to the casting part that is threaded to hold the valve tappet inspection plate to the cylinder block assembly. There is also not enough room on the other side either. I am working on a VH4 but would think the valves are the same in both engines. Maybe not?
I used that same valve spring compressor when I re-built a VP4 years ago. But the VP4 and VG4 are larger engines.
greygoat
11-25-2011 09:29:25
 Re: Valve spring compressor in reply to JOB, 11-24-2011 18:55:33
I've had no trouble with a "Snap-On" brand C
clamp type valve spring compressor, but it has 3
sets of spring compressor fingers...without
looking...I guess I just use the set that works/
fits.
JOB
11-25-2011 16:39:40
 Re: Valve spring compressor in reply to greygoat, 11-25-2011 09:29:25
The one I have is a New Britain VL 140 bought at NAPA many years ago. It is just too large for that size Wisconsin. I have two sets of fingers and neither of them will work. I will have to keep my eye open for another brand. I would hate to buy a new Snap-on for as often as I would use it.
Thanks Greygoat
