Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
waukesha two cylinder air cooled engine
leon r
11-15-2011 16:37:33
I could use some help identifying the age of this engine I was given. The engine has the waukesha manufactures plate with the number 580851. It is a flat two cylinder opposed air cooled engine with a Fairbanks Morse mag type J2B8 on it. I have been doing some googling but can't come up with anything. thanks, Leon
noncompos
11-17-2011 13:20:09
 Re: waukesha two cylinder air cooled engine in reply to leon r, 11-15-2011 16:37:33
These are apparently all variations of what is loosely (at least in parts catalogs) called/known as the Wauk "150" engine.
A 56 Fed-Mog shop specs manual shows both of the Crosley 2 Cyl's with OE part numbers "150xxx", similar to the Wauk OE numberng system used with 130s (130xxx) etc at that period. I don't have anything that lists the Cub Twin or its OE part numbers.
As John says, the Hist Soc (wehs.net) can give you more precise info on your unit.
J. Schwiebert
11-16-2011 17:44:11
You need to contact the Waukesha Historical Society
Duner Wi
11-15-2011 20:35:57
If I remember correctly Crosley used a 2 cyl. opposed engine 1939-1942. I doubt if it had a magneto tho.
leon r
11-16-2011 15:51:41
 Re: waukesha two cylinder air cooled engine in reply to Duner Wi, 11-15-2011 20:35:57
Thanks Duner, have been looking at the Crosley sites also. Sure is odd that there is not more info on the web about waukesha engines as they have been in business for a hundred years!! Leon
Duner Wi
11-16-2011 18:18:06
 Re: waukesha two cylinder air cooled engine in reply to leon r, 11-16-2011 15:51:41
Look at this
http://www.dieselpunks.org/profiles/blogs/lord-ks-garage-43-american
Says it is a "Cub Twin"
My 1955 Victor gasket catalog list a model 150 "Cub Twin" power unit with 3 X 3 1/2.
My Crosley book says 3 X 2 1/2 for 1940-42. For 1939 stroke was 2 3/4.
leon r
11-18-2011 15:36:17
 Re: waukesha two cylinder air cooled engine in reply to Duner Wi, 11-16-2011 18:18:06
Thanks everyone. The waukesha historical site also shows the air cooled two cylinder was introduced in 1938. Very interesting history on this company. It appears that the two cylinder air cooled was used on the early crosleys. My example has a bellhousing and clutch. Leon
