Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Stationary Engines Discussion Forum
Topic: kohler command 25 hp
[Return to Forum]
PAQ
09-29-2011 18:39:16
66.189.92.68
I have an Allmand loader backhoe that is powered by a Kohler command 25 hp engine.
It starts well, seems to have good power and it saves my back on at least a daily bases. The problem is that when it is hot and you shut it off for a short time and restart it, it will run on one cylinder for a while. Sometimes it picks up the second cylinder suddenly and sometime gradually. The book doesn’t give me a clue as to the problem. Sometimes it pops on shutdown which makes me think exhaust valve but compression seems good. I replaced the plugs and air filter.
So any suggestions?
Thank you in advance
[Reply]   [No Email]
Kentb of SWMO
09-30-2011 07:11:50
71.30.129.216
Re: kohler command 25 hp in reply to PAQ, 09-29-2011 18:39:16
Try checking the fire on the cylinder that is missing with a inductive timing light. If you have intermittent fire, I would replace the coil for that cylinder as it may have developed a heat problem. You could also swap the coil to see if the miss moves. One of the coil could be failing because of heat.
I had this same thing happen on a 22 HP Command engine. I thought the engine was tried as it was on a zero turn mower the local school used that had POOR air filter maintenance. I install a new engine. Later after seeing the inside a a single cylinder command engine that had eaten WAY more dirt that the v-twin had I took the V-twin apart. I could find NOTHING wrong with it. Later because of some operator errors, this engine was put back on the mower it came from. It seems to be running well. I do not know WHAT made it run poorly in it's earlier life.
Kent
  [Reply]  [No Email]
PAQ
09-30-2011 13:46:48
173.13.78.193
Re: kohler command 25 hp in reply to Kentb of SWMO, 09-30-2011 07:11:50
Thanks kent.
I will try that this weekend. It does seem like the kind of thing a weak electrical component would do.
PAQ
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
