Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Stationary Engines Discussion Forum
Topic: Re: Cold Start Engine
[Show Entire Topic]  [Return to Forum]
Kentb of SWMO
09-26-2011 05:24:11
98.23.175.218
The engine is a Briggs and Stratton. It has a small Flo-Jet with four bowl screws. This tells me that the engine is likely a 80000 series/3 HP. If it is a 120 VAC 60 HZ generator which is likely because of the twist lock plug, the generator will have a output of around 1250 Watts/10 amp. This is not a lot of power but if the power is out because of storm damage, 1250 Watts is better than NO watts. Clean the fuel system, change the oil, and pull the flywheel so the points that are behind the flywheel can be cleaned. The engine will run. You might need to flash the generator to get power as sometime during long idle periods, a generator will loose it's residual magnetism.
Kent
[Reply]   [No Email]
Excalibur farm
09-28-2011 17:21:06
184.9.203.232
 Re: Cold Start Engine in reply to Kentb of SWMO, 09-26-2011 05:24:11
It has a DC generator on it not an AC generator
[Reply]  [No Email]
Kentb of SWMO
09-30-2011 07:16:21
71.30.129.216
 Re: Cold Start Engine in reply to Excalibur farm, 09-28-2011 17:21:06
Check closely as you may have both a commutator and slip rings on the rotor because you need to generate a D.C. voltage for the field to produce a AC voltage.
Kent
[Reply]  [No Email]
Excalibur farm
10-01-2011 23:08:40
184.9.203.232
 Re: Cold Start Engine in reply to Kentb of SWMO, 09-30-2011 07:16:21
The DC voltage is the only rating on the tag. In order for it to be used as a cold start engine it would have to create DC voltage.
[Reply]  [No Email]
Bob
10-03-2011 09:38:59
64.255.159.192
 Re: Cold Start Engine in reply to Excalibur farm, 10-01-2011 23:08:40
Please define "cold start engine". I'm NOT familiar with the term and, it seems, GOOGLE isn't either.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
