TractorLinks.com
Stationary Engines Discussion Forum
Cold Start Engine
Excaliburfarm
09-07-2011 23:08:08
We have a small green engine in our barn that looks similar to a small generator. I was told by my father that it was a cold start engine used for starting diesel engins. Any additional information would be great. Also we may be interested in selling it. Thanks!
Kentb of SWMO
09-26-2011 05:24:11
 Re: Cold Start Engine in reply to Excaliburfarm, 09-07-2011 23:08:08
The engine is a Briggs and Stratton. It has a small Flo-Jet with four bowl screws. This tells me that the engine is likely a 80000 series/3 HP. If it is a 120 VAC 60 HZ generator which is likely because of the twist lock plug, the generator will have a output of around 1250 Watts/10 amp. This is not a lot of power but if the power is out because of storm damage, 1250 Watts is better than NO watts. Clean the fuel system, change the oil, and pull the flywheel so the points that are behind the flywheel can be cleaned. The engine will run. You might need to flash the generator to get power as sometime during long idle periods, a generator will loose it's residual magnetism.
Kent
Excalibur farm
09-28-2011 17:21:06
 Re: Cold Start Engine in reply to Kentb of SWMO, 09-26-2011 05:24:11
It has a DC generator on it not an AC generator
Kentb of SWMO
09-30-2011 07:16:21
 Re: Cold Start Engine in reply to Excalibur farm, 09-28-2011 17:21:06
Check closely as you may have both a commutator and slip rings on the rotor because you need to generate a D.C. voltage for the field to produce a AC voltage.
Kent
Excalibur farm
10-01-2011 23:08:40
 Re: Cold Start Engine in reply to Kentb of SWMO, 09-30-2011 07:16:21
The DC voltage is the only rating on the tag. In order for it to be used as a cold start engine it would have to create DC voltage.
Bob
10-03-2011 09:38:59
 Re: Cold Start Engine in reply to Excalibur farm, 10-01-2011 23:08:40
Please define "cold start engine". I'm NOT familiar with the term and, it seems, GOOGLE isn't either.
Excalibur Farm
09-19-2011 16:08:08
I finally got some pictures. I can email more
soundguy
09-20-2011 09:24:31
 Re: Cold Start Engine in reply to Excalibur Farm, 09-19-2011 16:08:08
I agree with bob.. its a 120v genny.
soundguy
Bob
09-20-2011 08:42:34
So, what information is stamped on the tag of your Briggs and Stratton-powered generator?
cole in mo.
09-17-2011 16:48:12
It could be a V4 john deere motor used to start the 70 through 830 john deere diesel farm tractors, as well as the 840 industrial jobs.
greygoat
09-08-2011 07:10:06
Are there any name tags or identification
on it? We need more information!
Excalibur farm
09-08-2011 16:13:09
 Re: Cold Start Engine in reply to greygoat, 09-08-2011 07:10:06
Its a Briggs and Stration Engine other than that a lot of the identification cannot be read.
Bob
09-08-2011 23:48:18
 Re: Cold Start Engine in reply to Excalibur farm, 09-08-2011 16:13:09
A picture is worth... (WELL, a LOT)!
