| Stationary Engines Discussion Forum |
Topic: Re: Ford power unit
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| huntingreen2day
09-02-2011 21:39:54
75.131.120.19
Sounds like the carb might be running out of gas. Might have to raise the float level. |
| JOB
09-05-2011 08:08:32
74.36.132.227
Re: Ford power unit in reply to huntingreen2day, 09-02-2011 21:39:54
| I felt the carb was set right. When cranking over the engine I could see the sediment bowl fill full of fuel quickly so I knew it was getting gas to the carb. I thought about blowing out the fuel line from the fuel pump back to the tank incase there was an intermintit blockage. Looking at I felt the carb was set right. When cranking over the engine I could see the sediment bowl fill full of fuel quickly so I knew it was getting gas to the carb. I thought about blowing out the fuel line from the fuel pump back to the tank incase there was an intermittent blockage. Looking at where the line in connected to the tank I discovered a shut off valve. This valve is not visible unless you put your head down under the machine. I turned the valve to see what position it was in and discovered it was almost closed. where the line in connected to the tank I discovered a shut off valve. This valve is not visible unless you put your head down under the machine. I turned the valve to see what position it was in and discovered it was almost closed. This valve would have had to have vibrated closed over the years until it got too closed. I forgot there was a valve down there. I had the entire machine apart 20 years ago. Runs again like a million bucks. |
| JOB
09-03-2011 11:14:42
74.36.132.227
| That was what I thought also. It is set like the book says. With the float installed turn that half of the carb upside down and the closest part of the float should be 1/4 inch above the gasket. I might just go a little closer and see if that helps. Thanks though |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
