TractorLinks.com
Stationary Engines Discussion Forum
Re: Rod and main clearance on Stover CT-2
kkaddatz
08-21-2011 13:20:54
That is true with Hit&Miss you usually wait. With never have had the engine running I'd try cranking it by hand first and see if you get any pop out of it. It not then I'd belt it up to one of the tractors PTO and let the tractor do the work while you adjust. Low idle on the tractor and be careful of the belt. Like the other said make sure you have the rod shimmed right before you try starting it. Squirt a little oil in the cylinder before you try starting it also.
