Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Rod and main clearance on Stover CT-2
greygoat
08-20-2011 18:39:45
If you set them for "Slight Drag", better make
sure that they're getting enough lube!
sflem849
08-20-2011 19:13:12
 Re: Rod and main clearance on Stover CT-2 in reply to greygoat, 08-20-2011 18:39:45
So there should be no resistance? I would compare their tension to a wheel bearing. I tightened them up until there was quite a bit of drag and then backed it off a notch.
The rod bearings are really touchy because there is no way to measure them (that I can think of) Can't you use plastigauge on the crank since it is a shimmed bearing and you are tightening the bolts down all the way?
