| Stationary Engines Discussion Forum |
Topic: Hey Greygoat
[Return to Forum]
| Author |
[Modern View]
| Bernie/MA
07-29-2011 09:56:00
159.250.60.238
My wis engine on my baler revs under no load and bogs down loaded. A couple weeks ago the arm from the carb to the gov broke and the engine wound way up before I could shut it off. Could a spring or something in the gov broke? If so what should I look for? TIA |
| greygoat
08-01-2011 05:45:25
75.121.145.186
Re: Hey Greygoat in reply to Bernie/MA, 07-29-2011 09:56:00
| In reference to JOB's answer..an owners and parts manual for your engine shows a photo and gives directions on how to do that. Get yourself an owners and parts book! |
| Bernie/MA
08-02-2011 09:03:28
159.250.60.175
Re: Hey Greygoat in reply to greygoat, 08-01-2011 05:45:25
| I found my book. Do those flyweights or the sliding sleeve ever break or stick? TIA |
| JOB
07-31-2011 19:40:20
74.36.131.181
| | This might be a dumb response but did you hook the rod from the carburetor throttle lever to the off set hole at the top of the governor lever? Is the governor spring hooked to the correct hole in the governor lever? Hole number six will give you a no load RPM of 2150 and a load RPM of 2000. Hole on the bottom of the governor lever is number one. The spring tension is adjusted by means of the adjusting screw on the spring to run at 2150 revolutions per minute at no load. If everything is hooked back up properly the engine should not have the problem you described. |
| Bernie/MA
08-01-2011 17:12:40
67.142.166.26
Re: Hey Greygoat in reply to JOB, 07-31-2011 19:40:20
| There were no springs or holes changed from where they were before the rod broke. Only two things can be different, the lenght of the rod and the adjustment screw on the carb where the rod connects. I didn't change that from where it was when I got it new. I shortened the rod about 1/8" so it would go into the governor top off set hole without moving the gov lever. It acts just like the governor isn't working at all, which led me to think the over-reving broke something. I have a book which I haven't dug out because I've had heat sickness. Thanks for your answers. |
| greygoat
07-30-2011 14:00:22
75.121.145.186
| There's no spring "in the Governor" but there is a spring holding the throttle, carb butterfly, closed, and the governer works against to in order to try to keep the engine running at a constant speed |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
