TractorLinks.com
Stationary Engines Discussion Forum
Wisconsin VF4D timming
Brian Dan
07-21-2011 17:19:40
I have a Wisconsin VF4D engine. It had no spark. I removed the magneto so I could work on it.
Are there timming marks on the gears that mate with the magneto? I see the x mark on the magneto but can't locate the other x mark.
What am I missing?
greygoat
07-23-2011 05:37:12
 Re: Wisconsin VF4D timming in reply to Brian Dan, 07-21-2011 17:19:40
A Wisconsin owners manual has some very nice
pictures of how to do that, and a good explanation.
Brian Dan
07-22-2011 11:52:14
Thank You! It took me a couple of tries but I did get the magneto back in and the engine now runs great.
JOB
07-21-2011 18:51:20
Remove the screen that covers the flywheel.That will expose the timing marks that are on the flywheel shroud. The flywheel is marked with the letters DC near one of the flywheel fins. the fin is further identified by an X mark cast on the end of the fin. Turn the engine over until edge of the marked fin on the flywheel is on line with the mark on the vertical line of the shroud. At this point the key way for mounting the flywheel is also on top. The magneto should now be fitted to the engine so the X marked tooth of the magneto gear is visible through the lower half of the inspection hole.
If the magneto is properly timed the impulse coupling will snap when the DC X marked fin lines up with the center line of the number 1 and 3 cylinder as marked on the flywheel shroud.
