TractorLinks.com
Stationary Engines Discussion Forum
BS Engine
MJ in the UK
05-25-2011 08:39:22
I have just got a Briggs & Stratton 8 HP air cooled stationry engine with the following details. MODEL 190452 TYPE 0549-01 CODE 74030210 SERIAL NUMBER E134158. I would like to know the age and any other details you experts can tell me about this engine. Thanks in advance. MJ
Kentb of SWMO
05-26-2011 13:28:12
 Re: BS Engine in reply to MJ in the UK, 05-25-2011 08:39:22
Engine was made in March 1974 from the Code Number (7403). I have never seen one with BOTH a code and serial number. Are you sure what you listed as a serial number is not the Code Number of a Short Block that may have been installed? The 19 in the Model number tells you it is 19 CID, a little over 300 CC's. The "0" is the basic engine series. The 4 tells you it is a horizontal crankshaft engine with a Flo-Jet carb. The "5" tells you it is a 6 to 1 gear reduction PTO. The "2" tells you it has a rewind rope starter.
Kent
MtMan
05-25-2011 19:55:38
Go to this site and you will find all the data you will ever need on BS engines. WWW.asecc.com/data/briggs/horsepower. Hoope this helps
MJ in the UK
05-27-2011 05:07:31
 Re: BS Engine in reply to MtMan, 05-25-2011 19:55:38
Thanks for the help guys. MJ
