| Stationary Engines Discussion Forum |
Topic: THD Wisconsin horsepower / RPM
[Return to Forum]
| Author |
[Modern View]
| Stephen Bushmaker
04-20-2011 13:27:05
97.127.15.249
I am setting up a 10 KW Generator (AC) and using a Wisconsin THD To power it. I am not clear on the correct speed or horsepower for this engine. Best As i can tell, 18.2 at 3200 RPM, or 16.8 at 3600 RPM. The gen set needs to turn 1800 for my application. I was going to use a tooth type belt or maybe v Belts. The gen set needs about 15 HP. Thinking about running the engine 3000 or 3200 RPM. I haven't bought pulleys yet. lots of options open. Input please?? |
| buickanddeere
05-18-2011 13:59:18
209.240.115.198
Re: THD Wisconsin horsepower / RPM in reply to Stephen Bushmaker, 04-20-2011 13:27:05
| Not enough engine for full generator output or to start motor loads. 7-8KW will have the governor wide open. |
| greygoat
04-21-2011 05:44:43
75.121.175.220
| As I answer this, I"ve got a Wisconsin TH/THD/ TJD shop manual in front of me. Max RPM of a model TH is 2600 RPM. For THD/TJD it"s listed at 18 horsepower at 3200 RPM. The chart does go to 3600 RPM, but horsepower drops after 3200. There are also "Specs" for barometric pressure, and altitude above sea level. "Allow 1% loss of power for each 1000 feet above sea level. ALSO:"For contionous use", "Deduct 20% of horse power as a safety factor". 20% of 18 is 3.6, so if you consider a generator as contionous, then rate the engine at 14.4 horsepower. I"ve got a THD on a 5KW generator and run the engine at 2400 RPM, where the book says it has 15.2 HP, (I don"t worry about altitude), and it does just fine with an Onan belt driven generator. I"ve always considered Wisconsins as low speed high torque engines and would never consider running one over 3000 RPM.Just pick a pulley combination to get your required speed. |
| Stephen Bushmaker
05-09-2011 11:28:18
174.20.101.50
Re: THD Wisconsin horsepower / RPM in reply to greygoat, 04-21-2011 05:44:43
| | Mr Graygoat; thanks again for your Reply. The pully combinatons are 18 and 30 for what I can get. Gives me an RPM of 3000. 10KW comes out to 13.4 horswpower, (100% conversion factor). can you tell me what the engines puts out (From your manual) at 3000 RPM? or where it drops below 14 HP (RPM)? Thanks in Advance, Stephen Bushmaker |
| Stephen Bushmaker
04-21-2011 09:06:30
97.127.15.249
| Thanks! That has been sort of my thoughts. I have another THD on my weld and power unit, it runs at 1800 or 2000, depending on your heat / power desired. We had installed this motor (From a concrete Saw) on a logsplitter, but didn't like crank starting at below zero Temps. We installed an electric start 14 on the splitter, this engine has been sitting sense then, Fresh .030 over, new vlaves. guess I'll shoot for RPM's under 3000. A well tuned Crank engine is a pleasure to start, at any Temp, but my partner never got the hang of below zero. For some reason I thought the max of this engine was 3200 RPM (Max Horsepower) and not 3600 RPM, (max speed). We had bought a manual but that seems to be on the Burried or lost list. Thanks for your Help! Steve |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
