johndeere model e 1 1/2 hp
The pin for the crankhandle used to have a screwdriver slot cut in the top and it just screws out, as long as it's not chewed up. Do you have to remove the flywheel?
The top of bolt is smooth with the flywheel,It also has side to side movement. I thought if i remove the flywheels i could adjust the clearance (?) Thanks
