Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Topic: How to get gear and taper pin off on Stover CT-2
[Return to Forum]
sflem849
03-18-2011 09:56:12
69.197.84.192
How do you go about removing a gear that has been welded on to the crank. This thing is BIG TIME welded on. They slopped a bunch of chicken crap on both sides of the gear and you can't even find the original shaft.
Could you torch it most of it off and have an engine shop turn it round again?
Are cranks easy to come by and relatively inexpensive? Would you be better off to cut the crank to get the flywheel off and buy a new crank?
These are the only options I can come up with, but their have to be more. I can't be the first guy to confront this problem!
Second
Is there a way to get rusted in taper pins out? It can't be punched or pryed out. Can you heat it? Will that cause problems with the flywheel?
Thanks
[Reply]   [No Email]
sflem849
03-21-2011 06:35:27
69.197.84.192
 Re: How to get gear and taper pin off on Stover CT-2 in reply to sflem849, 03-18-2011 09:56:12
Dad got all mad and said he is just going to leave the flywheels on and prep it for paint. I am not in love with the idea, but I am not the lead man on the project.
He wants to make the engine run before going nuts trying to salvage the crank. I'm guessing a crank could be had for that engine pretty easily anyhow.
BTW, it turns out it is a throttle governed engine. I don't know if that is better or worse, but at least we are not missing as many parts as we thought!
[Reply]  [No Email]
Eric in IL
03-18-2011 16:53:50
66.116.14.136
Well, there's always a way to save this old stuff if your pockets
are deep enough.
A good machine shop that has a CNC horizontal mill would
be a good place to start asking questions about removing the
gear. They should be able to use circular interpolation (
computer guides milling cutter in a circular path ) to cut away
the weld.
I don't think a large lathe is going to be an option with the
flywheels still mounted and in the way.
If you are going to talk to a shop, do it BEFORE you start
torching away at the gear. Sometimes torching can leave metal
harder than hell . Ask them if you can save them time by
torching first.
As to the taper pin, I may be able to give better advice if I
knew where it was located . I can offer that they are case
hardened and can be drilled after you get past the hard outer
skin.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
