TractorLinks.com
Stationary Engines Discussion Forum
Removing threaded pipe from exhaust manifold
motorcraftman
03-01-2011 18:12:17
This message is a reply to an archived post by Billy Shafer on September 25, 2010 at 07:26:53.
The original subject was "Re: Removing threaded pipe from exhaust manifold".
Hi... Billy, i have a One Cyl Wisconsin that has about One inch of what was once a muffler Pipe... waht Info. could You give me on this,,, Obviously I have tried the soaking fluids mentioned here Thanks Larry KF4LKU
Billy Shafer
03-04-2011 09:06:06
 Re: Removing threaded pipe from exhaust manifold in reply to motorcraftman, 03-01-2011 18:12:17
Sorry for the delay. Been busy getting a new shop ready to open.
The way I do it. Heat the pipe up until it glows. Then with a punch and hammer. Fold the pipe in on itself. It will fall out without damaging the manifold. The hacksaw blade works well. Just be careful not to damage the threads.
Kentb of SWMO
03-02-2011 07:26:10
I had to do this on a Briggs ZZ engine. The pipe was broken almost flush with the block. What I did was to use a hack saw blade to cut two places about a 1/2 inch apart into the wall of the pipe in the port. I then took an air chisel, caught the edge on the pipe between the cuts and chisel this chunk out. Then I collapse the rest of the pipe in the port an removed it
Kent
greygoat
03-02-2011 06:20:58
You're going to have to heat it!
I then use an "Internal pipe wrench" that
expands to grip and screw it out. I "Think"
mine is a Crapsman, (It's 5 degrees here in
Wisconsin, this morning...too cold to go to the
shop and check)
An "easy out" would work , on the heated fitting,
but who has one that big!
