Unit is on Ditch Witch. Just replaced With NEW Carb. and problem followed.
Starts fine , but must use choke during acceleration or letting clutch out, otherwise dies.
Problem has gotten worse, and now have to keep choke on to run, but still must momentarily add more choke when engine starts to load up to keep running.
Things I have done: fresh gas, made gravity feed tank direct to carb. : not better, maybe ran worse.
float level maybe? what shoud it be? seems like it is not getting enough fuel thru main jet??...
Thanks
Thanks
