Yesterday's Tractor Co.
Shop Now View Cart
Stationary Engines Discussion Forum
Hercules timing gear alignment
11-03-2010 14:08:41
I am rebuilding a Hercules Jxld that I got in a box. It is for a Oliver oc-12. The crank and cam gear both have S's and dot's on them. Not sure which to use for timing. If I line up the 2 dots the piston is almost at TDC but no all the way and the valves look like they are in the corect spot. If I line up the 2 S's it is way off. When I line up the dot on one and the S on the other the the piston is at TDC and the and the valves look like they are in the corect spot also.
Larry from MD
11-03-2010 14:19:58
 Re: Hercules timing gear alignment in reply to thawky, 11-03-2010 14:08:41
Line up the 2 dots.
11-03-2010 14:27:08
 Re: Hercules timing gear alignment in reply to Larry from MD, 11-03-2010 14:19:58
Thanks for the quick response. Kinda what I thought just wanted to make sure
