Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Stationary Engines Discussion Forum
Topic: Re: Briggs Intek V- Twin
[Show Entire Topic]  [Return to Forum]
Kentb of SWMO
10-29-2010 06:44:48
71.30.131.57
Alternator stator is under the flywheel. If tractor has electric PTO clutch you will have one of the higher output alternators with a regulator/rectifier assy. You should be able to unplug the stator from the regulator. Measure the stator for continuity with the engine NOT running. If you have continuity, start the engine, run to high idle and measure the AC from the stator. It should be around 40 VAC. Also check that there is 12 volts on the red wire to the regulator. Some, if not 12 volts on the wire with the ignition switch on but the engine not running, the regulator will not work. You could have a bad switch or a wiring problem. If all of the above check out, replace the regulator.
Kent
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
