TractorLinks.com
Re: VH4D Wisconsin Timing Compression
Operator4100
09-23-2010 02:59:41
Hey there, I dont have the manual but first look at your distributor see if there's a number 1 stamped on it,if your dist. has not been removed start watching the dist. when you turn it over slowy watching the rotor button,trace the plug wires if not even though its a 4 cyl. #1will be either left or right front cylinders generally the left I think,you can use your finger to see when you are on the compression stroke through the spark plug hole, theyre will be a whosssh when on compression, see if its firing order is 1,4,3,2 hope this helps, Dw
