Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Stationary Engines Discussion Forum
Topic: Interesting ignition on a stationary engine.
[Return to Forum]
Jon Hagen
09-19-2010 17:13:37
69.26.23.96
I was at a local steam threshing and antique show Saturday.
I saw two fellows starting a big open crank, hit and miss, stationary engine.
This one had about a 12 inch bore by atleast 12 inch stroke and flywheels of atleast 8 ft diameter.
Those guys kind of scared me a bit, they would monkey climb the outer rim of the flywheels and ride it down to let their weight turn that big engine. They would hop off about 45 degrees before the thing hit TDC and fired.
A great running old engine, "KAWHOOMP"!!!, then whoosh, whoosh whoosh for about 10 seconds until it needed to fire again. Painted green, but no identifing logo or name on it anywhere.
Late in the afternoon, I walked by the big engine again, it was shut down and no one around, so I had time to look the old engine over a little closer.
This engine had the typical moving points, low voltage igniter system like the old JD stationary engines with low tension mag had.
Only thing, this engine did not have a mag, it had battery ignition.
It had a small 12V battery with a wire running to a greasy old generator field housing sitting on the wood engine deck with fields still in place.
One wire went from a battery post to one field lead, aanother wire came from the other field lead to the moving terminal of the igniter. Another wire provided a return path from a bolt on the engine to the other battery terminal .
I was a bit puzzled by the old greasy field coils part in the ignition system, until I realized that with the igniter points closed, those old field coils would see 12V current flow and build up a magnetic field. When the points open, the magnetic field in the coils would collapse and cause a voltage spike of several hundred volts that would flash across the slightly open igniter points and light off this old engine.
I got a quick education about this type of ignition system and had to chuckle abouts the owners ingeneous use of a scrap generator part to make it work.
A few years ago I saw an ignition coil in a museum labled as for an early stationary engine. It appeared to have no secondary winding and terminals, so I wondered how it could work ?
I got my education yesterday :-)
I remember reading in vintage engine catalogs about how this type of battery ignition was standard on many engines, with a magneto being an extra cost option.
Overall a fun and educational day. :-)
[Reply]   [No Email]
Orgwayne
09-20-2010 06:47:58
206.125.73.241
 Re: Interesting ignition on a stationary engine. in reply to Jon Hagen, 09-19-2010 17:13:37
Jon , I know of a couple of young guys that do [ride] the flywheels, when they start large engines , and like you , I kind of fell like good luck guys !, they really know what their doing , but sure looks scarey
Wayne
[Reply]  [No Email]
Bob
09-19-2010 19:57:06
69.178.228.68
John, the "engage" windings of a large (diesel engine size) starter solenoid will work as a low-tension coil, as well.
A big 'ol filter "choke" from an antique radio makes a "hot" igniter coil, as well.
[Reply]  [No Email]
Tinker In TN
09-19-2010 19:27:34
98.240.25.175
Some folks use an old automobile coil. Just make your connections at the positive and negative posts, and use the primary windings in the coil for the ignitor ignition system.
Other folks say that the ballast resistor from a flourescent light will also work well.
You can also buy reproductions of the old time ignitor coils. It is said that a short fat one will produce a better spark than a tall skinny one.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
