Lister diesel
kendak
neighbor gave me two air cooled 6 cyl. Lister power units with clutches...anybody got any idea what they weigh?...were used up until a few years back to pump water on rice...thanks ...Kent
found out today...very close to 800lbs....got both home this morning...#97 HR6 A27 & 871 HR6 A28..88HP at 2000rpm...with Twin Disk clutch good to 110HP...thanks for the help...Kent
If you remove the flywheel. Don't get your toes between it and the floor. I think it is half the weight of the engine.
LOL ...right haven't got time to play with them anyway....I'm looking for a HR1 single cyl. ..6hp....we used to have 6 or 8 that we pumped water for the rice fields ...parts will inchange between 1,2,3,4 &6 cyl. if all are HR series...we had a few LR that were some tough little engines ran 24-7 shut off once a week to change oil...had one that ran 2 weeks with bottom half of the piston broke off..only knew it then when pieces came out when we drained oil...take care ...Kent
