I currently trying to work on my Coleman 3000 watt generator with 8hp Briggs & Stratton motor. Had to take apart and clean carb as it wouldn't start. Now need to get the governor set correct. When I start it the throttle plate is wide open, that doesn't seem to be right. If any one has any pictures of how the governor linkage should be and the procedure for setting the running speed and governor, I would greatly appreciate it. I would think that when the unit is running without a load the throttle should not be wide open. I would think the governor would open the throttle to maintain steady RPM and output as a load is placed on the unit.
Thanks,
Bill
Thanks,
Bill
