John Deere LUC pulley
Bunky1267
New User
I have a JD LUC and I want to remove the PTO pulley and put a Belt pulley on it, I took the nut off and tried to use a pulley to pull the pulley but it wouldn't come loose is the a set screw or something I need to loosen to get the pulley off ???
Also does anyone know if a belt pulley of a John deere MT will fit ??
Is this the right drawing... pulley bolts to a hub?
Looks like you remove cotter key, nut, washer and then pull the hub off of the woodruff key.
<img src = "http://i32.tinypic.com/koub8.jpg">
Thanks Bob for the photo, I want to put a Belt pulley on my LUC but after checking I appears the only way to do this is to remove the gear reduction and make a shaft for the crankshaft to mount a pulley on has anyone done this ???
I pulled the whol reduction unit off and putclutch plate and output shaft. The bolt pattern on motor is a starndart size I think my clutch housing came off an oliver
