Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
John Deere LUC pulley
Bunky1267
07-18-2010 10:27:19
I have a JD LUC and I want to remove the PTO pulley and put a Belt pulley on it, I took the nut off and tried to use a pulley to pull the pulley but it wouldn't come loose is the a set screw or something I need to loosen to get the pulley off ???
Also does anyone know if a belt pulley of a John deere MT will fit ??
gtx1967jewison
07-29-2010 14:19:31
 Re: John Deere LUC pulley in reply to Bunky1267, 07-18-2010 10:27:19
I believe an LUH has that setup already.
Bunky1267
07-24-2010 14:08:49
Does anyone know where I can get a Belt pulley for a LUC ?
Bob
07-18-2010 13:37:28
Is this the right drawing... pulley bolts to a hub?
Looks like you remove cotter key, nut, washer and then pull the hub off of the woodruff key.
Bunky1267
07-27-2010 06:56:18
 Re: John Deere LUC pulley in reply to Bob, 07-18-2010 13:37:28
Thanks Bob for the photo, I want to put a Belt pulley on my LUC but after checking I appears the only way to do this is to remove the gear reduction and make a shaft for the crankshaft to mount a pulley on has anyone done this ???
wilson
08-18-2010 13:08:43
 Re: John Deere LUC pulley in reply to Bunky1267, 07-27-2010 06:56:18
I pulled the whol reduction unit off and putclutch plate and output shaft. The bolt pattern on motor is a starndart size I think my clutch housing came off an oliver
wilson
08-18-2010 13:08:12
