Wisconsin engine parts?
The company is still in business and if you google them, a lot of their catalogs are available online. I recently got a fuel pump for an old Wisconsin engine from NAPA.
Also, there is a huge number of OEM parts for these engines on ebay.
I second that. Parts are readily available from Wisconsin. Not neccesarily cheap, but they are well supported for the most part. Somethings like clutches and reduction units might be out of production, but standard engine stuff is OK.
I fix mostly Wisconsin 2 cylinder engines, and
get most of the parts from NAPA
Valves, Rings, gasket sets, oil seals, Carb kits,
fuel pumps, are readily available. Points and
condensers for WICO, or Fairbanks-Morse magnetos
are available, but the new parts books don't show them, Napa can order them if you have the
numbers. "Yesterdays Tractors" has the magneto
parts also!
Hey and Good Evening, I was wondering if you have compiled napa part numbers? some of the guys on the Ford form have got lists compiled and have listed them for all to use, just a thought, Thanks, DW
