Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
YT Website Comments and Suggestions
Re: 1956 660 has been sitting for years ... what to try first?
davediehl@hotmail.com
12-07-2012 13:45:38
Change all fluids, everything! If you have a small shop vac with the small wand, clean out the tank if its been sitting dry. That is, as long as there is no gas odor present. Clean out the sediment bowl. Mix your fresh fuel with some 2 cycle oil and only put in enough to get started and 20 minutes of run time. No need to fill it as you may be cleaning out the sediment bowl a second time. I would have fresh cork gaskets on hand for the sediment bowl. Install a fresh battery and fire it up. If you need a starting aid, WD40 works best. Its not as volatile as starting fluid and will lube parts as its sucked in.
Copyright © 1997-2015 Yesterday's Tractor Co.
