Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
YT Website Comments and Suggestions
Topic: Re: 1956 660 has been sitting for years ... what to try first?
[Show Entire Topic]  [Return to Forum]
El Toro
12-05-2012 06:17:49
108.3.143.30
I would loosen the oil pan drain plug to see if any water is present. If there's water I would drain the oil and replace the oil and filter. Take a flashlight and look in the gas tank for any rust, dirt or gummy residue from the old gas.
It may need cleaning. Remove the distributor cap and clean the points with some 320 wet or dry until shiny. Fill the radiator with a 50/50 mix of antifreeze. Then check for leaks. Once you have the new battery installed and with the ignition switch in the on position & the points open take a volt meter or test lite and check for battery voltage on both small terminals on the coil. If there's voltage here put fresh gas in the fuel tank and see if it will start. Hal
PS: I would also check those gear boxes for water. They may need to be drained and filled with new gear lube. I would also install a new set of sparkplugs. I would also replace the plug wires. Only replace one wire at a time so you don't mess up the firing order. Place your request over on the Ford forum as you will get more responses over there.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
