YT Website Comments and Suggestions
Synchronization problems again
YTSupport
09-10-2015 16:53:19
Classic view broke synchronization with modern view at some point today. It was just pointed out in a thread on classic (see below). I have restored it and some posts that were not appearing are now, others have still not come through so I can't be sure they will.
I'll watch it. I don't know why it's started doing this again after all these years.
SweetFeet
09-10-2015 19:00:25
 Re: Synchronization problems again in reply to YTSupport, 09-10-2015 16:53:19
I replied to a post at 9:00 PM Central Time... and just got the same error message as John in LA.
So it might still be happening.
YTSupport
09-10-2015 19:03:22
 Re: Synchronization problems again in reply to SweetFeet, 09-10-2015 19:00:25
It's repaired, but the text of about 1000 posts was lost. Should still be there on the modern side and there may be something I can do to recover them, but classic may still show some fallout from this.
John in La
09-10-2015 18:51:46
Chris it is still messing up at 850pm central time.
Got this when I tried to past..... ...
Due to a system problem, the post you replied to only will allow replies on Classic View. Your reply was posted on classic view if you receive this message while you were at the point of posting (versus previewing), so dont repost it. Most likely, the original problem has been corrected but the post you were replying to was created while the database was down. Return to Discussion Forums. Error is 22
YTSupport
09-10-2015 18:58:47
 Re: Synchronization problems again in reply to John in La, 09-10-2015 18:51:46
Yes, there's some corruption in the DB and I'm fixing it now. It may have been what caused the other problem.
YTSupport
09-10-2015 18:02:32
I'm sorry to say that I don't think the posts that were not synchronized, will catch up. New posts from classic are working now. Sorry for the imposition.
