TractorLinks.com
YT Website Comments and Suggestions
Re: Problem posting pictures on Classic!!!
YTSupport
04-07-2013 07:54:02
JD, The problem Jim mentions was a specific version of Firefox (now replaced by Mozilla). It's not exactly the same but IE has had updates that can cause the same result. It honestly doesn't sound like you are having that problem but it is possible. Your config can change without you knowing it from Windows updates. Same for security software, it will update it self and change things around. But in this case, our server changed a couple of weeks ago and that is suspicious that it could be on the server.
The problem is that IE is protecting you when you don't want to be protected. Under some condition, it's not allowing the script to run thinking it's some bad script trying to access another site. Well, it is trying to access another site, tractorshed.com where the photos are stored.
If this is the problem. It means I have a bug in one of the upload categories where it's not (for IE's sake) calling tractorshed.com by it's yesterdaystractors.com name. I created a name of photos.yesterdaystractors.com to get around it. It may be that somewhere in my code, under some condition, it's not calling by the name Microsoft forces us to use.
I figured I'd test to all galleries today and see if any fail for me. Doing some other stuff at the moment and then I'll get to it.
One other thing that I doubt is the problem is that if you do anything, click back up to the text window etc, prior to the photo url being filled in, it will cancel the script that fills in the photo img url. Then the upload went fine, it just doesn't put the link in your post.
El Toro
04-09-2013 05:40:32
 Re: Problem posting pictures on Classic!!! in reply to YTSupport, 04-07-2013 07:54:02
I've had a few problems posting pictures within the last week, but when I try later the pics will post. Hal
YTSupport
04-09-2013 09:14:59
 Re: Problem posting pictures on Classic!!! in reply to El Toro, 04-09-2013 05:40:32
Is that the same sort of thing JD was talking about? Where the optional url box doesn't get automatically filled in?
El Toro
04-10-2013 05:58:28
 Re: Problem posting pictures on Classic!!! in reply to YTSupport, 04-09-2013 09:14:59
It doesn't do it all the time. You can still select your pic after clicking on "Browse" and the picture will appear after clicking on "Upload", but when you click on " Continue" the pic doesn't post. If you try later sometimes it will post. I'll try posting a pic here. Hal
YTSupport
04-10-2013 11:23:07
 Re: Problem posting pictures on Classic!!! in reply to El Toro, 04-10-2013 05:58:28
So far I'm drawing a blank on this one. The way I upload, it's working. If this is intermittent, I'd be tempted to think you are hitting a slowdown in the server's response. The script that fills in the URL Image box, has to run after the upload is complete and is sensitive to clicking anywhere else in the window, that can happen pretty easily if for some reason the network stalls and it looks like the process has stopped.
If it doesn't fill in the box, have you ever tried to reupload at that point and then have it fill in the URL?
YTSupport
04-10-2013 06:45:45
I'll try it repeatedly and see if that happens to me.
