2810 Ford hydraulic leak on gear shifts boots
We are talking about a 80 s model 2810, correct?
That model has the hydraulic pump mounted in the right side axle housing with no piping running thru the transmission case
Is it spraying out or just leaking out
To much fluid or water contamination can cause the fluid to foam up and leak out around the shifters and other areas
Pull the check plug on the right side and see if it s over full, if it is let it drain down to the correct level
If the fluid is milky looking remove the bottom drain plug and completely drain the trans, then refill to proper level with fresh fluid
(quoted from post at 16:26:46 06/22/23)
checked and it is milky. Drained and filled with fluid. Added some Lucas hydtaulic boost. Thanks for the help
