Tractor popping when choke is in when choke is pulled no
Because airflow is limited with the choke pulled out. Engine MIGHT have some broken valve springs too, causing the popping when valves are not closed when they should be.
It could be not getting enough gas, I've
had this happened and it was a restricted
gas flow. Once from a sediment bowl screen
and another time from a tiny piece of rust
below the needle valve.
