Looking for some help replacing a bad ignition switch on a 1985 JD 2150 Tractor. There was 5 wires going to the switch and I have identified only the BAT cable. The old defection ignition switch has no labels on any of the pins. The old switch had 6 pins but not all were being used. The new ignition switch purchase is clearly marked BATT/IGN/ACC/GRD/ST. The at attached pictures shows only the old switch. The PAT NO. Engraved on this switch is a standard 3497644. All of the switches I found on the internet with that number do not have 6 pins that look like this nor do they have their terminals ID as per what we have on the new switched purchased! Is there anyone that can look at the back picture of the switch I have posted from behind that have no wires attached to it and identify the terminals in this old switch in order for us to re-attached the wiring correctly to the new switch which is properly labelled? Thanking you in advance for your help. PS - I have the service manual for the JD 2150 and the Main Ignition Switch shown in the manual only has 5 terminals on it and looks completely different.
