Good morning all,
I recently acquired a Farmall 450 and was able to get the whole tractor running beautifully. The previous owner supposedly put on all four new brake discs, as well as new boots and new bolts for the cover. The brakes on the tractor are strong but they won't lock up the tires no matter how hard I depress the pedal, which I figured is fine. However, I'm in Maryland and we have a lot of hills. If I'm on a hill, the brakes will barely slow it down, no matter how hard I depress the pedal. On flat land, the brakes are able to stop the tractor sufficiently but require a bit of force if I'm moving fast. Could this be an adjustment in order to tighten them? Could something be together wrong like not lubed? Let me know your thoughts. Thanks, Ryan.
TDLR: Brakes stop the tractor on flat but won't hold the tractor's weight on a semi-decent hill, no matter how hard they're depressed.
Edit: If it makes any difference, the rears are liquid filled and have wheel weights.
This post was edited by RyanKve on 04/13/2023 at 07:28 am.
