Trying to remove the pto case on the rear end of a 4-180. We have it loose, but there seems to be something preventing it from sliding out. The shop manual we have is very vague. All the info I can find online or on YouTube are for the 2wd whites/Oliver s/mms and those show removing the pto drive shaft from the rear before removing the pto case. The 4wds pto drive shaft doesn t appear to be removed in the same manner. The best we can determine is that we need to disconnect the pto drive line in the center and pull the shaft out the front of the rear end.
Any helpful advice would be appreciated. Thanks!
