What would be the issues if the 3pt hitch only lifts my snowblower up a few inches by itself but lifts it fully if I lift on it and then if I put downward pressure there is resistance at first but then it lets go and falls to the ground(slowly)? I assumed the raising was a issue with the filter(at least hoping) and also hoping the lowering could be from the orings on the stand pipe. I did pull the little cover off the stand pipe today and when the tractor fired up fluid shot up about 16", so I assume the pump is working properly. The fluid is quite milky too and will be replaced when I get the filter. Also are the orings on the standpipe just standard size orings or are they a special size?
Thanks for the help.
